Assuming a typical 8" SCT Front Corrector Lens & Main Mirrror which had been infected with stubborn fungus for years. Assume they are more than 10 big fungus spots of about 2-3mm and more smaller ones around the peripherals. These fungus cannot be remove with typical optical cleaners Alcohol base cleanser.
Now I got a a powerful Alcohol base cleaner (MEK) which can remove almost any debris & marking even fungus on the Lens & Mirror. (had used that to remove the most stubborn dirt on my car!)
Should I then use this to remove all the Fungus infected spots on the Lens & Mirror knowing :-
- it will remove all optical coating on the lens & mirror
- it might also remove the mirror base Al coating
Or should I just let the fungus stays & spreads further :roll:
What is the expected optical loss/gain ?
Fungus - To remove or not to remove
Just a sidetrack, remember the German School we went last time, next Thursday evening will have another. Interested ?rlow wrote:Hi Wee Kiong,
Having cleaned out more than half a dozen different SCTs with fungus before, I think you should still clean it and not let it get worse. I use a mild non-alcohol cleaning solution. I can take a look and help out if you like.
Re: Fungus - To remove or not to remove
You should try to remove the fungus if possible. I myself cleaned my Celestar 8 the other day, it had some fungus after being mothballed for nearly 4 years.Lee wrote:Assuming a typical 8" SCT Front Corrector Lens & Main Mirrror which had been infected with stubborn fungus for years. Assume they are more than 10 big fungus spots of about 2-3mm and more smaller ones around the peripherals. These fungus cannot be remove with typical optical cleaners Alcohol base cleanser.
By the way, wear gloves when handling MEK, its carcinogenic.
Not sure if it is carcinogenic, but do please put on proper PPE (Personal Protective Equipment) and do it in a well-ventilated place.
The material safety data sheet (MSDS) is here:
http://ptcl.chem.ox.ac.uk/MSDS/BU/2-butanone.html
http://www.temarry.com/MSDS/Methyl_Ethy ... e_msds.htm
Please read before using.
Hi
Most of you report on having fungus on your optics.
Don't you all keep your stuff in a dry box?
BTW, once cleaned , can the optics be none of the worse? or can we expect a visible degradation in visual performance?
btw off topic here, Echelon, are you the same echelon from ppcsg.com?
- acc
- Administrator
You won't notice a visible difference in visual performance as the degraded optical surfaces are just a very small percentage of the overall area. Note how big the central obstruction of an SCT is (assume its a huge fungus on steroids) and yet, it still serves up decent views!
Please dun use that on the mirror and lens.Lee wrote:Assuming a typical 8" SCT Front Corrector Lens & Main Mirrror which had been infected with stubborn fungus for years. Assume they are more than 10 big fungus spots of about 2-3mm and more smaller ones around the peripherals. These fungus cannot be remove with typical optical cleaners Alcohol base cleanser.
