I make this when I first learn how to star hopping with a star chart and I find it very useful for planning the star hopping route and show you the coverage of your 5º finderscope.
There are 6 different templates:
1) Sky Atlas 2000.0 Desk & Field Version for Telrad
2) Sky Atlas 2000.0 Desk & Field Version for Rigel QuikFinder
3) Sky Atlas 2000.0 Deluxe Version for Telrad
4) Sky Atlas 2000.0 Deluxe Version for Rigel QuikFinder
5) Pocket Sky Atlas Telrad
6) Pocket Sky Atlas Rigel QuikFinder
The last circle is a 5º circle which is a very common 50mm finderscope field of view.
The left side is a scale ruler for estimating angular distance on the charts. The right side is the brightness scale of star used in the chart... use the height of the bar to compare with the width or height of the star in the star chart to estimate the brightness of the star in the star chart.
To use it, just print out on a transparency (don't print with scaling). Cut out the one that you need and laminate it for protection or put in one of those small plastics holder for pass.
Happy star hopping and have a nice day.
Star Hopping Aid
Star Hopping Aid
- Canopus Lim
Yup useful charts. I also made for telrad and 5 degree FOV for my Sky Atlas 2000 Deluxe. However I am not using it due to its sheer size and rather difficult to photocopy since the size is bigger than A4. I am using my PDA software instead which also can set the FOV and put a telrad circle, better still the FOV can be whatever possible orientation (inverted, mirror, correct, inverted-mirror.. 4 possibilities) and the star magnitude can go very deep and be set at certain magnitude.
