kayheem wrote:climbing up to HDB rooftops is Vin's specialty! :-)
However, don't try this at home!
I recall a similar thread sometime ago. Do try a search.
wah low....you still remember huh? haha
Well, Honestly I don't advise anyone to go up there. Anyway, most are locked, unless you go to those very new blocks and they haven't lock the top.
In any case, up there is not an open space. There are a lot of pipes and huge tall water tank. It is almost impossible to walk from one end to the other because of all the pipes and tanks. The only open space is at the top of the water tanks...you have a round space of around 3-4 meters (in diameter) only. But the problem is you need to climb up those vertical ladder to get on top of the water tank. Wind is also strong...not advisable for astrophotography. And if you fall off the edge of the water tank, then really bye bye.
Todate, I still don't know how I could bring a eq mount, a 8" SCT, accessories and even a 14" TV up to the top of the water tank. I don't think I want to do it again.
So please, don't go up there.
