hi,
Weixing and Vincent...... thankyou to both of you thru the guidance that both of you ,finally I managed to get my lens back on track.. :oops: :oops: at last it works again....
bro maybe yes maybe nolah..... got to come back work on Sunday lah....... will call you or sms you if i just bochap.. or just do obs with you than morning do or die go to work.... .
amin7074 wrote:hi,
yes initially terbaliklah after properly rework on it still does not works, get really fed ups :x :x my blood really goes high and dry than i noticed that my focusing tube does not travel like normal length....decide to take it out again and fix it......... :o :o actually there should not be any spacing between the two lens... :roll: took out the spacer ring place back the lens and it works again but with my finger print all over the both lens....kekekekeke . Thanks Bro... 8-) 8-)
actually there should not be any spacing between the two lens... took out the spacer ring place back the lens and it works again but with my finger print all over the both lens....kekekekeke. Thanks Bro...
You mean you actually took out the lens from the lens cell itself. I thought you only took out the lens cell out.... Anyway, I think there should be a little space in between the lens... All of the achromatic refractor I owned had three small piece of spacer (paper like spacer) instead of a spacer ring between the lens... may be the spacer ring was improperly space when you put the lens back.
Anyway, do give it a test on star when you are free and check did you notice any difference or problem without the spacer.
