The 2" visual back should have the compression ring to hold the diagonal or any accessory down really tight and firm.
Thanks!
WTB: 2" Visual back for SCT with 1.25" adaptor
Why do you need this item? In the first place, most 2" visual back is for 10" SCT and above. I have not seen a 2" visual back for 8" SCT and below simply because the hole opening itself is less than 2".yanyewkay wrote:still looking for the 2" visual back with compression rings.....
Even if you can find this, this item will not be secure enough to clamp a 2" diagonal and a DSLR camera. Furthermore, you have a 2" eyepiece also.
What you should get is a 2" SCT diagonal with SCT thread to screw onto the 6" SCT back. This will be dead firm because it's a screw-on. If you want to do prime focus, get a T-adaptor, screw onto the back of the SCT and then mount a T-ring on the T-adaptor
SCT <-- T-adaptor <-- Canon EOS T-ring <-- DSLR camera
OR if you want to use the 2" eyepiece
SCT <-- 2" SCT diagonal <---2" eyepiece <--- DSLR camera
Forget about that 2" visual back.
I doubt that visual back can hold a 2" diagonal, a 2" eyepiece, a Canon DSLR plus the camera holder. Especially considering the shape of the DSLR. During movement of the mount, I am sure the diagonal will slip no matter how strong you clamp the diagonal using that one small screw on the compression ringacc wrote:Hmm I have used a 2" visual back with an 8" SCT without problems leh... The advantage is that you dont have to go buy a 2" SCT diagonal if you already have a standard 2" diag.
Why want to take the risk epsecially when you have a DSLR there?
For prime focus:
SCT <-- SCT to 1.25"/2" adapter <-- 1.25"/2" T-Adapter <-- T-Ring <-- DSLR
or
SCT <-- SCT to T-Thread <-- T-Ring <-- DSLR
For eyepiece projection:
SCT <-- SCT to 1.25"/2" adapter <-- 1.25"/2" T-Adapter <-- 1.25"/2" Eyepiece Projection Adapter with eyepiece <-- DSLR
Anyway, ScopeStuff do sell them ( http://www.scopestuff.com/ss_adt2.htm ) or you can ask Astro Bargains to get it for you.
IMHO, you don't need a 2" diagonal even you do eyepiece projection. The 2" diagonal will just add more aberration to your image.SCT <-- 2" SCT diagonal <---2" eyepiece <--- DSLR camera
For prime focus:
or
