Foam for telescope case
tphilip
Post by tphilip »
Does anyone know where to get large blocks of high density foam for use in a telescope case? I have a large travel case and I'd like to cut some foam to shape to hold my scope in it. I don't want pluck foam or stuff which will outgas. Big fat sheets which I can glue together to form a large block would also work.
Thanks for any suggestions.
Tim.
mch3898
Post by mch3898 »
Somebody suggested yoga foam mats. I have not tried it but am going to explore the possibility.
Pluck foams seemed to be good but any idea where to get these separately, ie not with casings.
christopher
I have some of these foam to give should it be of interest. It was used to package telescopes.
Photon Bucket
mch3898
Post by mch3898 »
That's great. I will like to have some. (Enough to pack a C8 scope). How can I collect from you? Thanks a lot.
christopher
tphilip
Post by tphilip »
The size of my case is 75cm x 25cm x 25cm. What would be ideal is 5 sheets of 5cm thick foam which is 75cm x 25cm. Then I can cut and laminate the sheets to suit. Anyone have any idea where I could get sheets of foam in this size?
Thanks,
Tim
Have you tried Art Friend at Bras Basah COmplex? Maybe they have.
Found this thread.. Thought I read it before. All the best!
http://www.singastro.org/viewtopic.php?t=1668&start=0
I also have some free foams to spare, if you need more. :)
