It can be spilt into 2 small tube for easy travelling with it.
Easily do 250x on planets.
It is like new, new born in 2020.
Like the FS series, the FC series are apochromatic refractors with two-element fluorite lenses. The FC series have larger apertures and longer focal lengths than the FS series and provide outstanding performance both for the visual observer and the digital imager. The FC series has its own dedicated set of reducers and flatteners and is also able to use some of these accessories from the TOA series.
The FC-76DCU model features a fixed dew shield and smaller, 80 mm diameter barrel for the same performance in a package featuring reduced weight and overall length. It utilizes a 1.25-inch rack and pinion focuser.
Specifications
Aperture 76 mm (3")
Focal Length 570 mm
Focal Ratio f/7.5
Optical DesignDoublet Refractor
Tube Diameter80 mm/9.37 inches
Tube Length 656 mm
Tube Weight 4.2 lb
Included Items
Optical Tube Assembly
Visual Adapter TKP20005
Coupling (L) TKP00104
Aux Ring TKP20001
Eyepiece Adapter TKP00101
Coupling (DT) TKP20006B
Tube Holder
Dovetail
Contact me at 9457 0145, Wee Ern
