I have an old iOptron Minitower Pro computerised Alt-Az mount to give away to anyone who might want to try to repair it or salvage for spare parts. Includes everything in the original kit, including mount head, 1.5” tripod, 8401 hand controller, 4.2kg counterweight (compatible with newer iOptron mounts like CEM26), 12V 1.25A power adapter and cables.
It used to work fine, but after not using it for better part of 5 years, it appears to have failed. Now, when powering up, the hand controller lights up with the iOptron splash screen, but beeps at one second intervals without completing the initialisation. Could be a problem with the 8401 controller or electronics board on [img][/img]the mount.
PM me if interested. Self collect at Hillview Park condo.
Bernard
WTG: TAKEN: iOptron Minitower Pro (not working)
Re: WTG: iOptron Minitower Pro (not working)
can i have it?
You can, though prefer if it’s collected asap. Need to clear the space at home
you could switch on, and check if you can connect to the mount via wifi or usb cable to a PC with ioptron commander. Its a very good mount.
I tried connecting it to the PC via the USB cable a couple of weeks ago. The PC no longer recognises it. Hand controller is stuck at the initialisation screen and beeps continuously every 1/2 seconds. That’s why I’m surrendering it to whoever is able to give it a try - and perhaps succeed, or at least salvage it for the parts.
Re: WTG: TAKEN: iOptron Minitower Pro (not working)
Mount taken. Thanks.
