2. Televue 2-1.25 inch adapter - $25
Came with a Televue Everbrite diagonal but have no need for this. This is the set screw version. Machining quality is very good with tight tolerances and a nice anodized black finish.
3. APM CNC Tube rings - for 4 inch scope - $75
Solid and good quality CNC rings, should easily be a step up in construction quality and solidity from most cheaper rings.
4. Nikon T-ring for Nikon DSLR - $10
Allows you to adapt your Nikon DSLR to telescope threads for the chance to get your feet wet in astrophotography without a dedicated astronomy camera.
5. 2 inch to M42 aka T-thread adapter - $8
6. 2 inch to 1.25 inch adapter - $8
7. Silicone anti-vibration pads - $20
Cuts vibration times in half. Highly cost-effective.
8. Red svbony vixen dovetail - $25
Some markings, but perfectly functional. Very solid.
9. SCT 2’’ visual back - $30
Very good condition. Uses compression ring.
10. Televue 2’’ Everbrite dielectric diagonal -$ 240
99% reflective diagonal with perfect optical and mechanical build quality. Very minor sleeks.
11. Off-axis guider w/ helical focuser - $65
Purchased but found I can't use this. Great condition.
13. William Optics 0.8x Adjustable Flattener (AFR-IV) - $280
Only used once or twice. Suitable for all refractors F = 500mm to 1000mm.
Has adjustable backfocus so no more need to fiddle with spacer rings.
14. Televue 2x Powermate - $260
No eyepiece holder, but comes with T-thread adapter to attach to camera.
Glass is decent condition w no fungus but has minor stain. No effect on image.
15. Explore Scientific 40mm 68 - $340
Super large FOV. Performance very close to 41mm Panoptic for half the price.
16. Skywatcher Skymax 150 Pro 6'' Maksutov - $550
Collimation is super dead-on. Optical quality extremely good, very sharp view
and star test is one of the best I've seen.
17. Televue 2.5x Powermate -$230
Perfect condition. Compression ring version.
18. Celestron Ultima SV 2x Barlow - $85
Well-known as one of the best barlows, on par with the Televue 2x barlow. Very good contrast.
19. Zhumell 1.25’’ filter set - OIII, UHC, Skyglow, Moon - $70
$30 each for UHC and OIII. Take all for $70
20. Lumicon OIII premium filter (SCT threads) - $50
Has rusting like all older lumicon filters. Performance should still be very good in the center which is not oxidised.
21. Orion Ultrablock UHC filter 2 inch - $80
Highly recommended for visual contrast improvement on nebulae. In the same league as high end UHC filters but far cheaper.
22. Vixen optics 6x30 finderscope with bracket - $35
23. Laser collimator 1.25 inch - $25
24. Circle-T 7mm Ortho eyepiece -$55
Great condition. Compact and sharp eyepiece.
Pls whatsapp me at 8363 9397 if interested in any of the items above. Thank you!
WTS Misc Astro Items - Televue, Zeiss, WO etc.
Re: WTS Misc Astro Items
Hi bfds
Is item 3 and 5 still available?
If so pls reserve for me.,and post answer in this thread.
Then will arrange for mrt metup like last time. Thanks.
Hi yes, these are still available. Can arrange mrt meetup through the direct messages. Thanks!
Forgot to add, still have some extra items
7. Nikon T-Ring - $20
Attaches to Nikon DSLR to allow screwing onto telescope with T-thread.
8. Generic 2-inch to 1.25 inch adapter - $8
No brand, has 1x set screw to hold 1.25 inch eyepieces. Works well enough but a little less solid than more premium adapters.
Hi bfds
Can reserve also item 8.
Then will arrange for metup.
Thanks
Thanks
Sure, will reserve all mentioned items. Thanks
Hi bfds
Will call you tomorrow to fìx metup date time.
Thanks.
Thanks.
More items
9. CNC tube rings (for 4’’ scope) from APM
Black anodised CNC machined hinged rings. Feels solid and would likely be a good step up from cheaper tube rings. Asking for around ~$120.
Updated and consolidated some items.
Updated some items. New items added including a large capacity dry cabinet.
