This video is hilarious!
http://www.youtube.com/watch?v=ikpZJZFj3Wc
Why you should just get a dob :)
- acc
- Administrator
- Canopus Lim
- acc
- Administrator
haha true.weixing wrote:Hi,
Ha ha ha... May be he'll have better luck if he try to use his GOTO at night...![]()
If the battery isn't dead. If the 12V plug doesn't work loose from the socket. If the scope is balanced properly. If the clutch doesn't slip. If the alignment is done properly. If Autostar doesn't act up. If you don't bump the scope accidentally.
Ha ha ha... that's why I'm still using an EQ mount with only motor drive... even if my battery is "dead" (Touch Wood), I still can do manually tracking by only turning a single axis (RA).haha true. Smile Gotos are great when they work. But the moon, star and the sun must all be aligned lor... -->
If the battery isn't dead. If the 12V plug doesn't work loose from the socket. If the scope is balanced properly. If the clutch doesn't slip. If the alignment is done properly. If Autostar doesn't act up. If you don't bump the scope accidentally. Mr. Green Smile
