I am selling a one-of-a-kind alt-az mount with slo-mo controls.
I modified the EQ3-2 to work in alt-az mode with slo-mo controls. The fine controls is important during high magnification use.
http://www.singastro.org/album_pic.php?pic_id=843
The mount comes with:
1) slo-mo stalks
2) 2 counter weights (only 1 shown in the pic)
3) tripod and accy tray
4) saddle plate from denebman
I am looking at $390 neg. The modifications alone cost $150, not counting the cost of the saddle plate and the original Eq mount itself.
I will only sell this with or after the 8" Meade SCT as the mount was made for the scope.
Pls PM me if you are interested.
WTS: Alt-Az mount with slo-mo controls
- Clifford60
I do not get what you mean by 'saddle plate face up'. If you are wondering, yes, the scope can point straight at zenith with no problems. It is 360 deg around in azimuth and 360 deg in altitude (although for half of this range it is pointing below the horizon :-)Clifford60 wrote:Can the mount turn 90 deg so that the saddle plate face up?
OK, now I know what clifford60 is talking about.mrngbss wrote: What are the differences when using from this facing up position from the default facing sideways saddle plate position?
In the picture from the link in the first post, it is a side facing saddle. In this configuration, it is the easiest to balance the scope so there will be minimal vibration. The CG is more or less over the axes of rotation at all altitudes.
If it is a top facing saddle (like a normal photo tripod), it will be unbalanced once the scope tilts above a certain altitude. The CG is no longer over the axis of rotation, leading to imbalance, vibration and risk of the scope toppling over.
To answer your question, no, the saddle plate cannot face up.
Hope that helps.
- Clifford60
