Re: WTB : DSLR camera with lens
leslie128
Favourite scope: FRA600
Post by leslie128 »
Hi Wilson
Watch this:-
https://youtu.be/9ZPjew874GE?si=5o_QpoI8kQCUOLck
Depends on your budget. What is your budget?
For Lunar, you probably need a 150-600mm zoom lens (used one is about S$350).
For DSOs, you need minimum a star tracker such as SA 2i (about S$500 with no GOTO function for new) or SA GTi (about S$750 for new) or ZWO AM3 (about S$1,800 for new) depends your payload capacity (5kg for 1st two and 8kg for AM3 without counter wt.) and a ZWO ASISAIR Mini (about S$190 for new). Guide scope is optional depends on your budget.
ZWO mini guide scope, 40mm, f/4 with a 120mm mini guide camera.
An astro DSLR such as Nikon D810A (used one is about S$1.600) or an astro MOD (ha) DSLR. Or a Full Spectrum MOD DSLR with UV/IR cut filter and a clip in light pollution filter (such as L-Pro, ultimate).
For milky way, you need a 24mm focal length lens f/1.4 such as Samyang manual focal length, used one is less than S$150.00 and a stock DSLR.
You also need a tripod for SA GTi or AM3 and for your DSLR.
leslie128
Re: Re: WTB : DSLR camera with lens
Post by leslie128 »
Hi Everyone
After the person (Wilson) posted his question about he needs advise for lens and DSLR for lunar, DSOs and Milky Way astrophotography on 20 Jun 2024 (he mentioned he intend to get these gears here), he removed his post after I have replied him.
Admin, please clarify whether he has accidentally removed his post or due to other reasons. Thank you.
leslie128
Post by leslie128 »
leslie128 wrote: Fri Jun 21, 2024 9:30 am Hi Wilson
Watch this:-
For Lunar, you probably need a 150-600mm zoom lens (used one is less than S$800).
For DSOs, you need minimum a star tracker such as SA 2i (S$500-S$600 for new, with no GOTO function) or SA GTi (S$800 – S$1000 for new) or ZWO AM3 (S$1,900-S$2,200 for new) depends your payload capacity (5kg for 1st two and 8kg for AM3 without counter wt.) and a ZWO ASISAIR Mini (S$190-S$220 for new). Guide scope is optional depends on your budget.
An astro DSLR such as Nikon D810A (used S$1.600-S$2,600) or an astro MOD (ha) DSLR. Or a Full Spectrum MOD DSLR with UV/IR cut filter and a clip in light pollution filter (such as L-Pro, ultimate).
leslie128
Post by leslie128 »
Hi Everyone
In his post, the person (Wilson) mentioned that he is a newbie and he needs advise for lens and DSLR for lunar, DSOs and wide field Milky Way astrophotography on 20 Jun 2024 (he mentioned he intend to get these gears here), he removed his post after I have replied him.
Admin, please clarify whether he has accidentally removed his post or whether Wilson is the 2nd account of another user. Thank you.
leslie128
Post by leslie128 »
Hi Everyone
Admin, please check whether Wilson is the 2nd account of another user. Thank you.
leslie128
Post by leslie128 »
leslie128 wrote: Sun Jun 30, 2024 11:20 am Hi Everyone
Hi Everyone
leslie128
Post by leslie128 »
Watch this:-
For DSOs, you need minimum a star tracker such as SA 2i (S$500-S$600 for new, with no GOTO function) or SA GTi (S$800 – S$1000 for new) or ZWO AM3 (S$1,900-S$2,200 for new) depends your payload capacity (5kg for 1st two and 8kg for AM3 without counter wt.) and a ZWO ASISAIR Mini (S$190-S$220 foe new). Guide scope is optional depends on your budget.
Hi Everyone
leslie128
Post by leslie128 »
Watch this:-
Hi Everyone
I refer to a post dated 20 June 2024
In his post, the person (Wilson) mentioned that he is a newbie and he needs advise for lens and DSLR for lunar, DSOs and wide field Milky Way astrophotography on 20 Jun 2024 (he mentioned he intend to get these gears here), he removed his post after I have replied him on 21 June 2024.
leslie128
Post by leslie128 »
Watch this:-
Hi Everyone
Hardwarezone
Favourite scope: maksutov
Post by Hardwarezone »
It happens when the person delete their account , the second post inherit the topic. I've had a few topics that looks like i''m replying to empty air without context.
