Hi, check this out! A new gadget for focusing digital camera.
http://www.kwtelescope.com/FotoSharp_page.htm
Another way to focus your SLR camera
Anyway, this is very interesting and may be quite useful... just wonder does this adapter got the same length as a T-Ring?? If the length is longer, than coma corrector may not work properly.
I think the adapter just activate the lens mounting pins to "fool" the DSLR and thought that the "lens" is in manual focus mode.Interesting... wonder how it works. It seems to use the cameras focus sensors but doesn't say how.
Anyway, will the Nikon focus indicator light still activate if you achieve focus, but not using a lens... such as through a telescope via T-Ring??
I think that just an adapter than connect to DSLR lens mount and provide a Female T-thread for the telescope to connected to. You adjust the focus using the telescope focuser.hmm i assume there is a lens element inside to adjust focus ?
Telescope don't have infinity marking as they are not design for SLR use only.anyway objects that far would already require infinity focus ?
I think Canon do not have the auto/manual focus selector switch on it's body... it is on the Lens itself, so when you switch to manual focus mode on the lens, the focus confirmation light or beep (if enabled) will be activated when the lens achieve focus. But when you connected to telescope using T-Ring, the focus confirmation light or beep (if enabled) won't be activated even you achieve focus.i cant speak for canon, but nikons have a AF switch on the body right? just off it and u have snap at any focus distance.
i see.weixing wrote:Hi,
what i mean re:infinity focus is that, even viewing of DSO, moon thru human eyes, we already focus to infinity arent we?
i am not familiar with scopes so i never saw the focusing ring on 1 but shldnt it be focused to infinity already?
assuming my camera's focus works for all DSLRs, nikon's aperture priority mode must detect the lens. meaning to say, the lens must have CPU contacts (af lens). to use any manual lens (w/o cpu contacts), i must switch to Manual mode which basically switches off focusing and metering.
in Manual mode, whether u are in focus or not, it will still take a picture.
thanks for the insight for canon cameras
The gadget cataclysm linked to is something similar to this item in ClubSnap:
http://forum.clubsnap.org/showpost.php? ... ostcount=1
The only difference is that the first item comes with the adaptor all attached. The CS version is just a chip which you need to stick onto the T-ring. They also sell adaptors with chips for other mounts e.g. Nikon or Olympus to EOS mount:
http://www.tagotech.com/index_files/Page377.htm
I am not affliated with the vendor, I am just a happy customer :-)
- wucheeyiun
I have tried focusing with the mewlon with t-adapter ( no cpu contact ) on d200, and the focusing indicator appeared to work, it flickers as it getting focus. I will try again with the mewlon reducer when it arrives...weixing wrote:Hi,I think that just an adapter than connect to DSLR lens mount and provide a Female T-thread for the telescope to connected to. You adjust the focus using the telescope focuser.hmm i assume there is a lens element inside to adjust focus ?
1) Canon DSLR: metering still function (in manual and aperture priority mode) but AF indicator is disabled.
2) Nikon DSLR: AF indicator works but metering don't. (Unless you are taking lunar and planets, you don't need the metering).
According to the link kayheem provide, Nikon and Canon DSLR react opposite when a non-lens is attached to it:have tried focusing with the mewlon with t-adapter ( no cpu contact ) on d200, and the focusing indicator appeared to work, it flickers as it getting focus. I will try again with the mewlon reducer when it arrives..
- wucheeyiun
Infact for d200 metering can still works with non cpu lens or any telescope because it is TTL meteringweixing wrote:Hi,According to the link kayheem provide, Nikon and Canon DSLR react opposite when a non-lens is attached to it:have tried focusing with the mewlon with t-adapter ( no cpu contact ) on d200, and the focusing indicator appeared to work, it flickers as it getting focus. I will try again with the mewlon reducer when it arrives..
