Slomo knob/ handle for sale. accumulated in 15 years and found in drawer
item 1-7 are one set (2 pcs) and item 8 is loose (1pc each). Please take note for opening/ bore size
1) Unknown (probably Vixen) handle: 57cm (8mm bore) $30
2) Carton handle: 46cm/36cm (8mm bore) $30
3) Carton handle: 46cm/46cm (8mm bore) $30
4) Takahashi handle: 42cm/35cm (8mm bore) $30 – one is black and one is dark green
5) Takahashi handle: 427cm/3542cm (8mm bore) $30
6) Carton handle: 12cm/11,5cm (6mm bore) $20
7) Carton handle: 21cm/12cm (8mm bore) $25
8) Loose piece (1 each)
Takahashi handle: 25cm (8mm bore) $10
Carton handle: 6.5 cm (8mm bore) $10
Pentax handle: 36cm (8mm bore) $20
Pls collect at Admiralty MRT. (9.8.five.5.8.six.4.9)
WTS: Mount handle/ slomo knob
- KKK26
- Attachments
- Handle 2.jpg (122.93 KiB) Viewed 4384 times
Re: WTS: Mount handle/ slomo knob
Hi Koko
Can reserve for me ALL 8mm pieces.
Will call you tonight for setup at your place. Thanks.(if sold already pls inform in reply on this thread)
Setup replace with met up. My platform always changes this word for me
- KKK26
noted, see you
- KKK26
Left only
Takahashi Handle 42mm long & 6mm bore (1 pc): $15
