Sky Watcher V5 Hand Controller for EQ and AZ Telescope Control
42,000+ OBJECT DATABASE: SynScan hand controller with 42,000plus object database will keep even the most experienced astronomer busy for countless observing nights.
BUILT-IN USB-B 2.0 PORT for easy control via PC or firmware updates. the SynScan hand control becomes a repeater between the PC and the motor controller in the telescope mount. The application running on the PC controls the motor controller directly. In PC Direct Mode the SynScan hand control becomes a repeater between the PC and the motor controller in the mount.
ONLY COMPATIBLE WITH Sky-Watcher SynScan mounts as well as DSLR control via SNAP port
INCLUDES CABLES FOR BOTH EQ and AZ Sky-Watcher mounts
WTS: Sky Watcher V5 Hand Controller for EQ and AZ Telescope [SOLD]
- Bergkamp_
