Polar Alignment
Robin Lee
Polar Alignment
Post by Robin Lee »
Hello guys, have been out of the astro forum for quite a while. Lately, I am doing a proposal on purchasing dome observatory and equipments.
I think a GEM has a better upgradability or the same as a fork mount. The thing that fussed me for quite some time is how quick can the polar alignment been done. Since Polaris is not visible in our latitude, do you use drift alignment?
Please share your alignment method and tips here. :)
Clear skies,
Robin.
kingkong
Post by kingkong »
if you are getting an obs, i assume it is feasible to keep the mount installed in there for extended period of time, hence you don't have to worry about alignment all the time.
you can drift align your mount to your heart content, leave it, and use it for a while. when you are bored, drift align it again. repeat.
to use, just mount your scope of choice and start - no need to align at all. i've never used a fork mount before but i imagine you might have problem with going to zenith...
Since it's going to be a dome observatory, it's doesn't matter how long does it take to do polar alignment... basically you just do it once.
Yap... drift until you can't drift anymore... :)
boothee
Re: Polar Alignment
Post by boothee »
Kim Miau wrote:Please share your alignment method and tips here. :)
Hi!
Here are some links from me. . .
http://www.andysshotglass.com/DriftAlignment.html
http://www.darkskyimages.com/gpolar.html
Clear Skies!
boothee
Robin Lee
Post by Robin Lee »
Oops.. I forgot the scope will be temporary used outside out the dome before it has been built. It will be ready around 2011, so there are 4 years to go. So, I take this into consideration.
Furthermore, we do sidewalk astronomy often. Do you guys drift alignment everytime?
Please share your opinions.
Clear skies,
Robin.
No... only when doing imaging.
Robin Lee
Post by Robin Lee »
So, what type of alignment and how do you do when it's only for visual?
Clear skies,
Robin.
jermng
Post by jermng »
point north
Jeremy Ng
C8, CR-150HD, TMB 80 f/6
Minolta Activa 12x50WA
Robin Lee
Post by Robin Lee »
Mind to explain in detail? :)
Clear skies,
Robin.
perseid
Post by perseid »
For visual observation, you do not need to align your mount to a high degree of accuracy. If you have a compass, just align your polar axis parallel to the compass needle.
As you are living in the southern region, which is quite close to the equator, then you just have to tilted your declination axis just a little bit. Even if you were to fully level the declination axis, it should still be fine.
