WTS: Tripods, cases, powertank ....
Post by Meng Lee »
Hi all, selling some stuff again:
1) Storm Case - $200 (reserved)
http://www.stormcase.com/StormCaseSizes/StormiM2400.htm
Similar in size to Pelican 1550 and you can sit on it, its tough. There are 3 layers of pluck foam. I can put back most of the foam. Highly suitable for Mount heads and there is space for the controllers.
[s]2) Vixen HAL 110 Tripod legs - $350 (See Hal 130 in the website, its the same, just shorter)[/s]
http://www.company7.com/vixen/mounts/tripods.html
This is the much stronger tripod legs compared to AL 130 (Porta mount legs). I modified the mount base, so that you DO NOT NEED a half pillar to put the mount on it. You reduce 2.2 kg of weight and get much better stability. Skyview Pro, GP, GPD2 heads work very well with it.
[s]3) VC 200L reinforced aluminium case - $250[/s]
http://www.vixenoptics.com/acc/cases.htm
This is not the kind of china made aluminium case. This is reinforced at the edges and at the sides. Extremely strong with fitting foam for VC 200L and VMC 200L. I believe it can fit 8" SCTs also, but its better to try and fit first.
[s]4) Orion refractor padded case #15161 (39" x 9.5" x 11") - $100[/s]
http://www.telescope.com/control/produc ... t_id=A0006
It fits refractors up to 900mm focal length, such as ED 100, and also fits tripods. The biggest telescope that can go in, should be takahashi TOA 130.
All in SGD. Thanks for looking, PM or sms me at 92732997.
Post by Meng Lee »
5) Vixen LV 40mm x2 for binoviewing - $300 for 2 pieces
[s]6) Vixen LV 8-24mm zoom eyepiece - $ 150 (reserved)[/s]
Updated. Thanks for looking.
Post by Meng Lee »
Picture of the Eyepieces:
Post by Meng Lee »
Add 1 more:
7) Celestron Powertank 7AH - $100
My electricity requirements have exceeded 7AH already. Everything is working fine for the powertank. The charging adapter has a crack that I have mended already. I added a switch on the powertank, so that any lead-acid battery can connect to its posts and output in cigarette lighter form. In about 6 months time, the battery inside needs to be changed. It is about $30 from Sim Lim Tower. I will provide the service to replace the battery without covering the cost of the new battery.
Thanks for looking.
Post by Meng Lee »
Upzzzzz
Post by Meng Lee »
Still available:
5) Vixen LV 40mm x2 for binoviewing - $280 for 2 pieces
7) Celestron Powertank 7AH - $80
Thanks for looking.
