APO fever again, die!
http://www.grandeye.com.hk/megrez_72.htm
http://www.teleskop-service.de/William/ ... m#Megrez72
Introductory price in UK is 299 Britsh pounds !!!!!!
Grandeye sells it at 2990 HKD ~ 556 SGD !!!!!!!!
Fever strikes again!
New WO 72mm Megrez !!!
Ah Stop it. Sigh, maybe my Ang Bao money will be used for Megrez 72 ,
Hmmmmmmmmmmmmmmmmmmmmmmm
Yah, recently I have shipped my WO stuff direct from Taiwan, very fast, the next day you wake up and open your eyes, it will be right in front of you.
Photo Album:
Wah good memory, yes I have the Megrez 80 FD, but what I don't like about it is that, even with the 0.8x flattener, I still need extension tube and rack quite a lot of focuser to reach focus with DSLR, which creates rather troublesome balancing issues.
I was hoping the Megrez 72mm does not have to extended so much (with 0.8x) to reach focus, then the DSLR + guidescope setup need not be so tricky.
Photo Album:
Photo Album:
Yah correct, I had the APOGRADE upgrade, so in normal visual setup, en extender tube + 2" diagonal is needed.
Oh, if the tube is too long, hmm this is actually a tougher problem. Then need to buy 1.25" diagonal instead, yah actually more expensive than buying extension tubes.
Photo Album:
