Hi, the super quick way is to go to Photoshop, Images, Adjustments, Levels and select the "set gray point" dropper and click the dropper on the red sky glow and most of the glow will be gone.
i use Nikon View, i sharpen 3X to amplify the bright spots, this amplifying algorithm is the most fool proof to me.
Remove the red channel , and do your own variable brightness.
there will will get the effects you want.
Thanks for yr efforts guys......hahaa~~
Will explore further on my own.
wucheeyiun yrs seem to be sharpening the noise....
Anybody knows if there is any LPR filter that can screw onto 67mm thread?
