Alternative material for telescope tube?
confuseguy
Post by confuseguy »
Other than metal like aluminium etc, is there other alternative material available in Singapore to replace my damaged C4.5 tube? [smilie=confused.gif]
You can also consider using a cardboard tube (like sonotube), UPVC pipe or construct with plywood. You can check out online or some ATM books etc for examples.
confuseguy
cardboard tube sounds good.....Upvc is just too heavy..heavier than aluminium?
I'm not really a handy man...but where to find this sonotube or I can actually find someone cut the holes etc~
hommel
Post by hommel »
Sonoco manufactures these sonotubes, but not sure if they
sell to end user, been to the factory many years back to see
the manufacturing of these tubes.
http://www.sonoco.com.sg/
28, Pandan Road, Singapore 609276
Tel : (65) 6264 4533
Fax : (65) 6264 0061
confuseguy
hommel wrote:Sonoco manufactures these sonotubes, but not sure if they
Thks man. I still go n ask for a quote.
branzzz
Post by branzzz »
carbon fibre tubing? but must source from usa. did some research long time ago and remember coming across stock tubing in many large sizes
For carbon fibre tubing, check to make sure you get a stiff one, and not a flexible type like those used for flexible dew shields.
did anybody manage to get a sonotube or core tube out of sonoco SG?
