SMC observed under Singapore sky
Clifford60
Post by Clifford60 »
At last found SMC with the 25x100 bino under S'pore sky:lol: , a small blur patch, 15 deg lower and to the right of Achernar. However. still can't find LMC.
questionmak
Post by questionmak »
Nice job Clifford, SMC was supposedly 15 deg from the horizon to the south? Must have fought of alot of skyglow to spot it?!?!?!
Clifford60
Once you found it, it is quite easy to locate it again.
wow cliff...amazing you managed to find it here in singapore with the permanent horizon cloud and urban light pollution! [smilie=admire.gif]
zackae
Post by zackae »
Haha cliff, someone should go capture it's image..... Then compare it with Smc taken from Austrailian skies or smth lol.
sehchoi
Post by sehchoi »
Oh my... Cliff, where did you spot smc from?
The last time I saw SMC and LMC was in NZ... miss those days... ^_^
Seh Choi
I try to observe SMC in Singapore before... I know it should be in the field of view, but just can't see it. :(
Anyway, the 47 Tucanae (the second largest and second brightest globular cluster in the skies), which is just beside the SMC, is very nice... :) You should be able to see it too as it's big (nearly as big as Omega Centauri or the full Moon size), bright (in DSO standard) and very close to SMC (should be in the same field of view as SMC using binocular).
Dragon Man
Post by Dragon Man »
Well done, Clifford.
Must be very hard to see from up there!!!!!
Here is about half of the Small Magellanic Cloud imaged on a slightly foggy night:
and a close-up of the same image:
The Globular Cluster 47Tuc is way off the side of these images.
Cheers, Ken :D
Snake Valley, Australia
President: Snake Valley Astronomical Association
mill
Post by mill »
Looks like we are very spoiled here in Australia.
I just can't imagine what the view would be Singapore :(
acc
Post by acc »
wow congrats Clifford! yet to see it from Sg. Really muz make a star-gazing trip to Oz or NZ! :)
