How to mount Zenithstar onto Ioprton Mini Tower?
spica42
Post by spica42 »
I just received my Ioptron minitower but I realized that the dovetail on my Zenithstar 80 would not fit into the clamp on the minitower. Anyone knows the best way to mount it?
Anyone able to sell me the relevant parts? :)
Thanks.
You will need a Vixen type dovetail (may not be necessarily a Vixen brand dovetail).
spica42
Post by spica42 »
How do I mount the scope onto the Vixen type dovetail? Do I need the mounting rings?
There should be some holes/slots for you to fasten the dovetail to the bottom on the Zenithstar.
This is what I used to do/have.
What i used is a Vixen brand Universal dovetail plate, used on a Tak saddle plate (which has the same Vixen style dovetail/saddle type).
The Vixen brand has a slot which I put two screws through to screw it onto the tripod plate that is found on my WO scope.
Hope this helps.
spica42
Post by spica42 »
You know where I can buy the dovetail plate? Or where I can get a second hand one?
jermng
Post by jermng »
Hi Spica, I've got a few extra, let me know if you're interested.
I've also got an extra saddle plate which incidentally, I got from mrngbss a while back. :)
Jeremy Ng
C8, CR-150HD, TMB 80 f/6
Minolta Activa 12x50WA
spica42
Post by spica42 »
PMed you. :)
spica42
Post by spica42 »
I borrowed an Orion dovetail plate, unfortunately the holes are not the correct distance apart. :(
Post by Meng Lee »
Oh, just take the orion dovetail to the bench drill with a 6mm drill bit and drill the right spacing.
Or purchase this:
http://staropticsscientific.com/telescope_accesories
Universal dovetail plate (2662)
