Which telescopes are worth buying?
lucasng13
Post by lucasng13 »
I would like to enquire on which telescope is worth buying. Thanks loads !
Re: Which telescopes are worth buying?
lucasng13 wrote:I would like to enquire on which telescope is worth buying. Thanks loads !
Astro=Physics scopes.
swat_pup6433
Post by swat_pup6433 »
hmm.. maybe you would like to specify what is your definition of "worth"? depending on your needs, different kinds of scope and different design would be considered "worthy". do you need a beginner start up scope? an imagining scope? or one for collection so you can sell it off at higher value in the future?
lucasng13
Post by lucasng13 »
Well,i would like one which has certain measuring tools in it. One that is able to measure the distance between stars(doesn't need to be accurate though, just a rough gauge). Thanks haha
Just the distance of the stars? Or would you like the size and mass of the stars?
What is your budget? I think most observatories' measuring equipment costs somewhere $100,000 and above (in USD), excluding the scope.
swat_pup6433
hmmm measuring the distance between stars.. well if you are talking abt distance in terms of light years.. quite impossible to afford one here i guess.. but if you are talking in terms of arc seconds and degrees maybe you could work out by calculations using the effective FL of ur scope together with a grid reticle projected on an eyepiece
lucasng13
Post by lucasng13 »
Well,just the distance of stars will do. Which brands do you recommend?
lucasng13
Post by lucasng13 »
swat_pup6433 wrote:hmmm measuring the distance between stars.. well if you are talking abt distance in terms of light years.. quite impossible to afford one here i guess.. but if you are talking in terms of arc seconds and degrees maybe you could work out by calculations using the effective FL of ur scope together with a grid reticle projected on an eyepiece
Thanks for the reply haha. I'll try to find out how to use the FL of the scope and a grid reticle to find out the distance between stars.
Post by Meng Lee »
And when you reach the ability to measure angular distances to around 0.3 arc secs then u are ready to use parallax measurements to tell the actual distances to nearby stars.
