Hi all, I know may of you will be interested:
http://www.centralds.net/en/index.htm
Its a korean company that does DSLR modification for astro and seals the sensor with Peltier cooling to prevent condensation!
ML
Commerical AstroMod DSLR + sealed Peltier cooling!
- swat_pup6433
Wow I wonder how intense the power consumption becomes..Peltiers are really not at that efficient.
Even the "high efficiency" ones.
This mod should not affect regular photography at all, unless it involves extreme exposure lengths, in which case you will improve the CCD response (less hot pixels / noise).
Just leave it off when you're doing regular photography.
- swat_pup6433
Oh well since the filter has been changed, daytime photography is never as good as before even with custom white balance.
Photo Album:
Ah ok I didn't notice that part thought it was just peltier addition.
If I was going to remove filters though, I'd just go with a purpose built CCD instead of hacking up a camera.. additional cost and mounting weight for no good reason![bleeding [smilie=bleeding.gif]](./images/smilies/bleeding.gif)
(I guess you wouldn't need a laptop then, but it would probably be cheaper to buy a laptop than a mount that would track better with a DSLR on the back)
I did my 450d modification with peltier cooling for less than 80 USD.
http://thaiastro.nectec.or.th/hypermod/
Anat
Anat
