Is Anti-Blooming a must in CCD imaging?
Jingguo
Post by Jingguo »
I just read that some ccd camera comes with Anti-Blooming features. Is Anti-Blooming a criteria when choosing CCd camera? Can software actually correct Blooming? or by just taking shorter exposures to avoid it?
MooEy
Post by MooEy »
if u rotate ur camera btw exposures, u can clean up blooming with some median computation when stacking. most sony ccd u see out there are anti blooming, so not much to worry about.
Post by Meng Lee »
Blooming CCDs have these advantages
1) Higher Quantum efficiency
2) More linear response. Good for making scientific measurements, especially photometry.
MooEy
Post by MooEy »
slight correction, it should be non-antiblooming ccd. a very good read would be ron wodaski's book, explains very well the diff btw anti-blooming and non antiblooming ccds. however do note that most of us are using anti blooming chips, since they are more available.
Fuzzy
Post by Fuzzy »
Heh, wouldn't a non-antiblooming CCD be a blooming CCD?
if you are planning to shoot really faint stuff like galactic clusters, etc, get the blooming one. otherwise anti-bloom CCDs are fine. I am using one. But blooming artifacts are easy to remove through software, so you should let this influence your choice in picking one.
Photon Bucket
