Solar Filters
Solar Filters
Anyone has any cheap, good solar filters to recommend? For 4" refractor. Best if it's one of those with a mounting cell to attach to the telescope.....
You can try Baader's Astro Solar Filters, they are available in singapore. I believe you can contact Remus regarding this as he carries this product. More information on this filter at http://www.star-matrix.com/prices/filters_baader_so.htm
Baader's Astro Solar Filters is one of the lowest price Solar Filters avaiable, but you must handle it carefully. Since it is just a piece of film, you can quite easily "pop" a hole or scratch it without notice it. So check for "holes" or scratches everytime before you use it.
If you are getting the Baader Astro Solar Filter which is good and relatively inexpensive, you have to make your own mounting cell, which is quite easy, but make sure it is very secure on the scope because you don't want it to accidentally come off the scope while someone is observing thru it.
Hi ChaosKnight,
Yes, the Baader Astro Solar filters are available. An 'A4' sheet costs SGD$50. Immediate stock. You can send your enquiries/orders to sales@star-matrix.com. Stay tuned for Venus Transit Projects soon!
i want to buy the baader astrosolar for the venus transit.
sent an email to sales@star-matrix but no reply yet :|
can anyone please help?
this is how i'm planning to mount it:
the 102 cap has a second 60mm opening...
i'll stick the baader astrosolar sheet inside the cap and just use the smaller opening for observing the sun. no chance of it being blown off.
shouldn't be any problem right? since the sun is so bright. aperture is not an issue. no?
next thing is how to aim....?
can use a piece of cardboard behind the finder scope. stand in front of the finder scope with back to the sun. and use the projection on the paper to aim.
probably have to close off or remove the finder scope when observing through the eyepiece. otherwise may get zapped.
Make sure you stick it securely and make sure to check that the solar film got no holes before you use it. Also, you don't need to use the finder scope to aim at the sun. Just aim the scope at the general direction of the sun and use the lowest power eyepiece that you have... the 25mm eyepiece that come with the scope should give you 20x and around 2.5 degree field of view... you should be able to locate the sun quite easily.
what's the safest/best way to check for holes?weixing wrote:Hi,
you don't want to find out with your eyes that there's a hole right?
perhaps without the eyepiece - ray not focused?
or project it on to something with/without the eyepiece?
