Today i came out the house at around 5.45am. I saw 2 bright objects. I know one of them is jupiter. But what's the other object? The brightness was same as jupiter. I did not observe using my scope as i was rushing.
haha any idea?
2 bright objects
Correct me if I'm wrong, at 5.45am, Venus and Mars should be quite low. Although, yes, if the other bright object is not near to Jupiter, then it should be Venus.weixing wrote:Hi,
The overhead bright object is Jupiter and the bright object at the eastern sky one is Venus... you should also be able to see the not that bright Mars above Venus.
), but there was no pass for ISS this morning, so the conclusion should be Venus.
He didn't mention where was the second bright object leh, but any star like object that as bright as Jupiter should be Venus and ISS (err... and may be headlight of aircraft when flying toward his directionZephyrus wrote: Correct me if I'm wrong, at 5.45am, Venus and Mars should be quite low. Although, yes, if the other bright object is not near to Jupiter, then it should be Venus.
First of all, how near were those 2 bright objects? Were they very close to one another, or were they far apart? Were they very low in the horizon, or very high up? Almost near zenith and 2 bright object is close to one another would be Jupiter and Altair or Formalhaut. If the 2 object is far apart, the one nearer to zenith is Jupiter and the one low in the horizon would be Venus.
The brightest object would be Venus at mag -4. Second brightest is Jupiter at mag -2. Followed by Vega (star) at mag 0. Vega would be rather low in the horizon at 5.45am. Nearest bright object to Jupiter is Formalhaut followed by Altair.
You should download Stellarium and check for yourself since you did not mention how far were those 2 objects apart from one another.
