I am keen to pick up astrophotography and have bought some equipment here in the US. I am returning to Singapore next year, so my equipment are really meant to be used in Singapore in the long run.
I had originally planned on a light 80ED, but ended up with a WO FLT-110 TEC (715mm, f/6.5) instead. Because of the original plan on the 80ED, I got an Orion Sirius EQ-G mount.
The Sirius mount is rated at 30 lbs. I understand from here and other forums that for AP, the rated weight capacity should really be halved or at most used at 2/3 capacity.
The FLT-110 with rings, focuser and an Orion Starshoot Pro cam weighs in at about 20 lbs - already the 2/3 limit. I plan to add a guidescope - originally wanted a ST80 but have now decided on the KWIQ or 9x50 finderscope to cut down on weight.
So all in all, I am probably looking at about 22 lbs on a mount rated at 30 lbs. No doubt a bit heavy for AP from what I have read!
I have some questions which I would be grateful for any help:
1. I think I read that because of Singapore's light polluted skies, long exposures are not feasible even for DSOs. Instead the trick is to take shorter exposures of DSOs and then stack multiple images together - is my understanding correct?
2. If that is correct, do 5 mins exposures sound ok for DSOs? I read from CN forums that someone with a similar set-up as mine was able to get 5 mins out of his Sirius mount before he had to throw away exposures excessively. So if the Sirius can do 5 mins exposures without great difficulty, would stacking these images together work in Singapore skies?
3. Would the KWIQ/finderscope guidescope option work in Singapore skies? Would it be too small to spot guidestars?
4. I have also read about this program known as WCS which allows drift alignment to be done via a CCD camera and on the computer. I am thinking of using this with an old DSI I have. Does anyone have experience with this in Singapore?
The main advantage of the Sirius mount is that it is light. But I have read from the experts here that if one wants to AP right, then weight should not be an issue. Since I may be able to get these mounts cheaper while I am in the US, I am keen on getting the right equipment before coming back to Singapore next year.
Looking forward to all your comments
Thank you!
