I'm putting together some new imaging gear and have some difficulty connecting some together. I would appreciate it very much if someone could tell me the correct type of spacer, etc to use:
First up I am trying to connect a Orion Starshoot Pro to a FLT-110 with dedicated flattener.
The flattener comes with 2 adapters - the cone-shaped one can screw into the SSPro but that is without the extra extension onto which I can screw on a 2" filter. I would like to have a space between the SSPro and the cone-shaped adapter. Does anyone know what is a suitable spacer/extension tube for this? It would be good if the spacer accepts 2" filters too.
A picture may explain the problem better; in the picture which follows the SSProII can screw into the flattener, but I would something extra between the two, preferably with the ability to accept 2" filters:
Still with the FLT-110 with flattener, I now have a DSI Pro III with filter wheel which I would like to attach to the flattener. However there seems to be no way to do this. I have the DSIPro connected to the filter wheel to a 1.25" to 2" adapter. If the flattener were not there, the 1.25" to 2" adapter would fit nicely into the 2" focuser, but the flattener is there. Is there something which can accept the filter wheel/DSIPro set-up into the flattener?
Again, some pictures:
Moving onto another instrument,
I now have a Televue 0.8x reducer/flattener which I hope to connect to the Orion StarShoot Pro. Again, the flattener connects very well directly onto the SSPro without the extender which accepts 2" filters. However, because I need a 56mm space to achieve focus, I need something between the SSPro and flattener. Again, it would be good if this can accept 2" filters. I would appreciate it if someone could tell me what this could be.
Again some pictures; this picture below shows the SSPro, the flattener, and the extender which screws onto the SSPro but cannot in turn be connected to the flattener.
This next picture shows the SSPro with the extender and 2" filter attached. However this set-up does not screw onto the flattener.
Finally, I have the DSIPro connected to filter wheel to the Televue flattener. However I do not think that the 56mm is met, and may require an additional spacer. Again, it would be appreciated if someone could tell me what this might be.
Some pictures of this:
I have checked out some possibilities:
http://www.agenaastro.com/ProductDetail ... 5&CartID=2
http://www.agenaastro.com/Blue-Fireball ... s10022.htm
However, I am not familiar with the difference between a "T thread spacer ring" and a "2-inch/1.25 inch spacer ring".
Any help would be tremendously appreciated. Thank you
