How to mount rigel finder to WO 90?
Bergkamp_
Post by Bergkamp_ »
I cannot find any place to mount it.
Most of the rigel user use the double sided tape provided and stick the rigel base on the scope OTA.
Bergkamp_
Post by Bergkamp_ »
Ic.. is it the transparent gel like thing? I used up the "glue", any where can get it?
You should be able to find similar double sided tape on those DIY shop.
Bergkamp_
Post by Bergkamp_ »
Weixing, many thanks!
I'm not sure if the double-sided tape will not mar the paint finish...
I have a Telrad and Rigel and would like to attach one to my WO 70..
Bergkamp_
Post by Bergkamp_ »
i use blue tac..
timatworksg
Post by timatworksg »
You could check out the HomeFix DIY shop for a 3M double sided tape which is also clear. Use it at work and its strong, thick and cushy, plus easy to roll off when used. Doesn't mar surfaces or leaves residue. When I go back to work tomorrow I check for the name.
Bergkamp_
Post by Bergkamp_ »
oo.. thanks!
