The picture was taken from a vantage point in the Bromo-Tengger-Semeru National Park known as the Mt Penanjakan viewpoint (reportedly at 2770m / 9087 ft).
Spanning the entire foreground landscape is the approx 10km wide Tengger caldera (i.e the crater top of a stratovolcano), which itself contains another 5 volcanic cones, of which the most well-known is Mt Bromo. To top it all, in the background of the foreground is the tallest mountain in Java, known as Mt Semeru (a.k.a Gunung Mahameru), at 3,676m / 12,060ft.
The view is quite amazing!
More info on that area can be found here:
http://en.wikipedia.org/wiki/Bromo_Teng ... ional_Park
As one of the cones (Mt Bromo) can be seen emitting clouds of smoke, the theme of this image could be: galactic clouds over volcanic clouds. How about that?
This particular image was taken at the crack of dawn whilst the stars were still faintly visible and as the foreground landscape was slowly being lit. Therefore, when I later adjusted the contrast and brightness levels with Photoshop, it was quite difficult to find the right balance between the foreground landscape and background sky.
Incidentally, that was the night of the Perseids peak, and I managed to see about 15 meteors, including 3 quite bright ones. More about that later.
For now, here are the image details:
- Single exposure taken with Canon EOS 350D, 20 seconds at ISO 1600, Sigma 17-70mm lens at 17mm at f/2.8. Birghtness/contrast adjusted.
[Edit in July 2012: broken photo links in this thread repaired]
