initial reports.. are not encouraging:
http://tech.groups.yahoo.com/group/iopt ... essage/125
any news / reviews on the ioptron iEQ45?
- orly_andico
- orly_andico
@andeelym.
My first EQ mount is an Orion Sirius EQ-G. You may want to have a look at this as your first EQ mount also. With the software EQMOD (open source, freeware) as a plug-in to the mount, it becomes very versatile.
It may not be the best mount there is but it is a well-tested mount, having been in the market for quite sometime and is designed for max load of 30lbs.
It can be adjusted for use at our latitude.
I use PHD to autogude with it and has at least met my use as someone who is picking up astrophotogaphy only the past year or so.
christopher
@mch3898:
How many stars does it need to get aligned? iOptron is able to do a 1-star alignment which is great for me.
I am willing to invest in a mid level mount as I would like to expand my gears so it may get more than 30lbs in the future. And i would rather spend more now than to try to sell and buy another later.
don't be too happy at the 1 star alignment...
the 1 star is determined by the hand controller, and they have a few to select from, but if all the stars happened to be blocked or somehow out of sight, then the 1 star alignment fails horribly and you're stuck..
then u have to do plan B:
point north, do a rough slew with GOTO to a target, if target is not in the FOV (usually isnt), manually adjust the RA DEC by pressing the hand controller to centre target, press align.
and for this plan B, u need to choose the brightest star..seriously brightest brightest, else all looks the same...
- orly_andico
@andeelym:andeelym wrote:@mch3898:
That's the beauty of the Sirius with EQMOD. It allows n-star alignment. I link it with Stellarium, the wonderful freeware skymap, and you can use almost any star that is visible in the sky for alignment - no more restricted to what is in the handcontroller. (i did a rough polar alignment with a cheapo compass first).
Yes, 30lbs is not a lot but for astrophotography, you can get decent images with small scopes - at least for a beginner like me. And the Sirius is quite a grab and go mount and so get used frequently. I use the WO90 and autoguide with the Kwik scope - all pretty light weight. And the Meade DSI Pro.
christopher
@mch3898
Oh is it? You gotta really shed more light on this to me.
I am using a meade LX50 8" SCT with a Canon 5D Mark II via a 2" system. My heaviest setup will be the above with a 2" WO Diagonal and a Baader 8-24 clickzoom and a 2" filter. Eventually, i'll add a refractor to the fray for guiding... so frankly, i am not sure of the eventual weight. But I definitely wanna get something that is over and above what I currently have with some buffer to expand.
