I have a 550D, awesome camera in many ways.
But as many pointed out, for any kind of narrowband filtering, you will need to remove the IR filter. I don't suggest you do this with a good brand new camera.
I'm also looking for a LP filter that will work with my unmoddified 550D.
Get the camera without the lens, then get the Tamron 18-270. This will give you a much wider range - better general purpose lens.
Frankly, if you are going to use the camera solely for AP use, you should go for a dedicated astrocam instead. The imaging time can be cut down as the sensors are more sensitive. But you need a PC/notebook for use.
DSLRs does have the convenience of not needing a computer to be attached to the camera though.
Agree with andeelym, the 550D is too good of a camera to be used only for AP. ( I assumed shirox will take normal photos first and AP second).
So, if you are taking mostly normal photos and some AP, then the 550D is great.
If just getting a camera just for AP, then the astro CCD will work better.
I got a used 40D for just about 600 SGD. Have no plan of modding it though, but definitely will be using it.
Kochu is still selling that modded 300D for $250 was it. If you mod the camera and use the "best" native ISO (which is 800) then a 300D is plenty good enough for AP.
You may (or may not) agree with his conclusions. The Nikon D3 is very well known for fantastic high ISO performance.. but according to Christian, it is just "at par" with the Canon 40D, a much older camera.
If you don't want to read the whole article, here's one of his whopper conclusions:
Assuming that the quantum efficiency of sensors are equivalent (it is highly probable in first approximation), the displayed sensitivity of 6400 ISO for the Nikon D3 #1 corresponds to a sensitivity of 600 ISO for the Canon 40D, while a sensitivity displayed at 6400 ISO for the Nikon D3 #2, corresponds to a sensitivity of 2400 ISO for the Canon 40D. Analysis shows that the "displayed" ISO announced by Nikon is very over evaluated relative to Canon competitor.
But i read that Nikon raw files have some problems that will cause problems to stars, especially smaller ones. And canon raw files are actually more "raw" than nikon's raws.
