What do you think of the Meade Series 5000 80MM Apo scope?
Nigel_Choy
Post by Nigel_Choy »
Have anyone have a first hand experience with this scope? Is it any good for astrophotography? Would like to know.
Thanks
IMHO any 80mm class ED scope will be good for astrophotography.. but make sure to get the flattener. Whether its a doublet or a triplet, you still need that flattener.
here's a blog post i made about why you need the flattener
http://orlygoingthirty.blogspot.com/201 ... er-ii.html
if the scope is long (e.g. f/9 refractor) you may get away without a flattener, although I haven't tried it.
if you're using a Schmidt-Cassegrain (SCT), even though these scopes are long (f/10) they have a lot of field curvature.. so you still need a flattener.
This is why the AT65EDQ is such a nice scope. It's a four-element ED so no need for a flattener..
That said there's a new flattener on the block which is damn cheap.. the Sky-Watcher one
http://www.firstlightoptics.com/proddet ... _flattener
not sure where to buy it though, seems only sold in the UK. It is good (better than the William-Optics flattener/reducer) but it is only a flattener, it doesn't reduce.
If I were you, go buy a scope and flattener from William-Optics in Taiwan. Their scopes are better than the Meades and Celestrons (in my experience) plus they are nearby, shipping isn't too expensive. They have an online shop as well.
orly_andico wrote:That said there's a new flattener on the block which is damn cheap.. the Sky-Watcher one
Sky-Wtacher also had flattener/reducer (http://www.skywatchertelescope.net/swti ... class2=512). You can get them through local Sky-Watcher dealer, McGill (http://www.mcgill.com.sg).
