Suggestions needed on preowned GM8 and GP2. The mount will be using for visual and simple Astrophotography purpose? Strictly I am not fancy with GOTO. I need durable, accurate tracking, flexible, solid, lightweight, peack2peak 10 to 20 and mid weight capacity.
1: GM8 comes with controller, PEC, Autoguider and dual stepper motor drives.
2: GP2 comes with Starbook (StarBook may not last longer, looks like toy).
Which is worth?
Rgds
Kimo
GM8 or GP2?
- orly_andico
- orly_andico
Hi kimo
You must mean the GP2 with the Orion dual-axis drive right?
Buy a GPUSB from Shoestring astronomy, and the DIY kit also from Shoestring (the "Guide Port Conversion Kit for EQ-style mounts" which is $8.00)
Then read this guide
http://www.store.shoestringastronomy.com/eq_mod.pdf
Total cost.. a little bit over $100 USD, plus some soldering required. If you want, I'm sure some folks here on the list could help you with the soldering (I don't know my travel schedule so I can't commit.. yet..)
Altogether that will give you autoguiding.
This is what I did with my GP + DD1/MT1, and I can autoguide fine.
- orly_andico
Hmm... I thought the mount will be use for visual and simple Astrophotography purpose?? You might not need an autoguider if your imaging scope focal length is shorter than 1000mm... just shoot multiple of 1min exposure and stack lor.
- orly_andico
not sure about the starbook-S... but somebody wrote an ASCOM driver that talks to the (regular) Starbook via its built-in Ethernet port.
so you can actually connect a wifi access point to the Starbook, then you can control your Sphinx from an iPad or laptop wirelessly. Same thing holds for autoguiding.
not sure if the -S model has ethernet though.
Like I said, the cheapest solution would be a GPUSB and then mod the Orion controller. That is what I'd do in the situation...
but as weixing points out... with a good polar alignment and around 400mm focal length, you can get 1 minute subs easily with no trailing.
