Aaaarrgghhh...... I need some desparate help from atro n especially ETX gurus. I tried to key in the info of comet NEAT from NASA emphemeris into the ETX. The outcome is like tis when I select NEAT from ETX :
ETX:
R.A. : 8h43m m d= degree
DEC: 27d 29'
while Heavens Above gives,
R.A. : 8h 44m30.7s
DEC: 24d29'31"
1)The autostar is 1min lesser in R.A. while 3d more in DEC compare to actual sky situation, why?
2)If I use a 25mm modified achromat 50d FOV ep, producing 14x magnification, wat are my chances to spot it?
3) The problem is also there when I key in info for comet LINEAR also 1min lesser 3d more, why?
I could not seek for the comet manually as I do not hav a finder scope. The comet is going dimmer day by day n the worst thing iz dat I am stuck in camp saturday night only time to observe. It is always cloudy then. Haaaaiiiiizzzzzz.
