need help with adobe photoshop!
- blazingice
- carlogambino
Not exactly. For planetary work, people usually take about 200-300 to stack them using registax and the results can be quite pleasing . Whereas for constellations + DSOs, people usually take a very long exposure usually varying from 20 mins to 40mins. However, you can also take 3 pics of each 10mins to stack them (eg. for globulars).carlogambino wrote:mak,pple dun do one time exposure, they tack short exposures using registax then edit using photoshop...
IMHO, i'll rather go for the conventional slr cams as they do not have noise. So, the things that will interfere with how well the pics turn out are
1. the sky
2. quality of lens
3. film
4. tracking time
In comparision, ccd cams are good for long exposures, but they produce a relatively large amount of noise unless you have a cooling fan. slr cams are good for long exposures, but they need tracking to show the same amount of detail as the ccd cam pics which are processed.
cheers,
wenyi
- carlogambino
hmm... but i thought the reason why pple use ccd cams are cos of the short exposure, so that very precise tracking is not required.(no need to polar align within a few arcminutes). However, due to noise build up for long exposures, they do short exposures instead(with tracking,but no need so precise polar alignment) and stack them... true?
nope. people usually use ccd cams becos there isn't a need to track manually at all. The computer does all the calculations for PEC(periodic error correction) and so they can do long exposures as well. However, due to the noise build up, the exposure time is limited to usually < 10 mins.
cheers,
wenyi
cheers,
wenyi
Those short exposure shot is suitable for planetary imaging only. The main reason for taking a lots of short exposure images and stack them together is to capture the details of the planet without over exposure... it had nothing to do with tracking accuracy or CCD noise. For DSO, you still need long exposure. How long the exposure depend on your tracking ability and how well your CCD camera handle with noise.hmm... but i thought the reason why pple use ccd cams are cos of the short exposure, so that very precise tracking is not required.(no need to polar align within a few arcminutes). However, due to noise build up for long exposures, they do short exposures instead(with tracking,but no need so precise polar alignment) and stack them... true?
CCD or film, you still need to do tracking or guilding if you take long exposure, unless you are taking star trail astrophoto.nope. people usually use ccd cams becos there isn't a need to track at all. The computer does all the calculations for PEC(periodic error correction) and so they can do long exposures as well. However, due to the noise build up, the exposure time is limited to usually < 10 mins.
didn't add 'manually'.
cheers,
wenyi
cheers,
wenyi
I think you get mix up with the CCD camera on the guide scope or the off-axis guider and the camera that take the picture. You can still use the auto-guider system when using Film camera. You are not using the guiding CCD camera for taking pictures.nope. people usually use ccd cams becos there isn't a need to track manually at all. The computer does all the calculations for PEC(periodic error correction) and so they can do long exposures as well. However, due to the noise build up, the exposure time is limited to usually < 10 mins.
