need help with adobe photoshop!
hlyf
Post by hlyf »
hi all,
i took some photos when i went for a malaysia trip last month, and just downloaded photoshop.. but i realised i dunno how to use it to improve on my photos :? so can gimme some tips on this? thanks :D
anyway, i've attached a sample photo, milky way faintly visible :D
Did it capture the milky way?? Can't really see it in the image.
Anyway, I think 15 second is a little too short to capture the milky way... try a longer exposure or use a higher ISO setting and also use the raw mode to store the image.... The jpeg sometime will "kill" those faint milky way image during the compression process.
By the way, those nice milky way image is normally the result of very long exposure.
Re: need help with adobe photoshop!
hlyf wrote:hi all,
15 sec not possible to capture milky way ....those you capture there is the main constellation of sagi and scorpius.
At 15 sec, there is very little you can do with photoshop. Maybe you can try to increase brightness or contrast to see if that brings the stars out a little more.
Photoshop is only useful if you do stacking.
[BPST]FerMIons&BOsOns
Location: Superclster>Local Supercluster>Local Group>Milky Way>Orion Arm>Solar System>Earth&
Post by [BPST]FerMIons&BOsOns »
hlyf is that the enstien cross u have in yur avatar
acc
Post by acc »
[BPST]FerMIons&BOsOns wrote:hlyf is that the enstien cross u have in yur avatar
This is a reminder to all members to avoid going off-topic. Chats should be conducted in Coffee Corner or via PM. Pls read the Singastro guidelines if you have not already done so:
http://www.singastro.org/viewforum.php?f=20
chrisyeo
Post by chrisyeo »
Hi BPST,
Welcome to Singastro. Please read and try to adhere to the rules and guidelines in the forum page before your next post.
Thanks,
Chris, Moderator
opps sry!
AlwAYs HuNgRy FOr KnoWLeDge SuckiNG ThEm In LiKe A BlACk HolE MuHAHAHA
hlyf
Post by hlyf »
hmm yeap okay thanks for advice..
and anyway.. yeah that's einstein's cross :)
blazingice
Post by blazingice »
Anyway, just to comment, i.m.o. I think that it's not easy to use Photoshop to work with images with so little contrast. For any image, in general the higher the contrast of the picture, the easier it will be to work with the image. That's because when the contrast is higher, the boundaries of objects in the image will be clearer, and thus you can edit them more easily. Filters will work better too, as their effects can be more easily seen.
•°o.O ߣãZïñG Ï©€ O.o°• /
MooEy
Post by MooEy »
hmm.. this is the best i managed to get. pic too underexposued.
