Hi
I am considering a 30 - 40mm eyepiece (used or new). My budget is around 200-250SGD.. So that leaves the Pentax, TV's out of my range..
Looking forward for your recommendations for an ep with a good price/performance ratio..
Recommendations for 30 - 40mm ep
Re: Recommendations for 30 - 40mm ep
What scope do you intend to use it with? If it is a long focal ratio scope e.g. SCT, MCT or long refractor, the 1rpd 30mm (80deg FOV) is pretty good value for money at US$99. This is apparently the same eyepiece as the BW Optic.addy wrote:Hi
- harlequin2902
There is a TV 40mm in the Buy & Sell going for S$160.I am considering a 30 - 40mm eyepiece (used or new). My budget is around 200-250SGD.. So that leaves the Pentax, TV's out of my range..
http://www.singastro.org/viewtopic.php?t=1190
Samuel Ng
the televue is a good deal. the meade series 4000 super plossl is also not bad as long as you do not require wide view...lesser vignetting.harlequin2902 wrote:There is a TV 40mm in the Buy & Sell going for S$160.I am considering a 30 - 40mm eyepiece (used or new). My budget is around 200-250SGD.. So that leaves the Pentax, TV's out of my range..
There will be a 2" 36 mm Meade 4000 eyepiece with 70 deg FOV coming out soon at US$99. http://www.buytelescopes.com/product.as ... d=7697&m=2
