jupiter problem
linkage2011
jupiter problem
Post by linkage2011 »
C11HD + 2x
Mount:NEQ6
Caputer:QHY5 @50fps 80s
Process Soft: Registax
it seems the satellite of Jupiter not round enought. and i have no idea why is that so -0-
Re: jupiter problem
Its an 80s exposure. I would think that satellite is moving much faster than Jupiter is rotating? :)
linkage2011
Re: jupiter problem
Airconvent wrote:Its an 80s exposure. I would think that satellite is moving much faster than Jupiter is rotating? :)
will it be due to moving too fast? it shall not be the case.
it shall be any big issue, if with in 120s for shooting Jupiter
i guess it could relate with Optical Axis. any one come cross this issue before?
cataclysm
Re: jupiter problem
Post by cataclysm »
It could be an artifact from stacking. If you are experiencing excessive movements from frame to frame, stacking registration may focused on the main globe while missed out on the outer regions. Try stacking with fewer frames and see if this will go away. :P
Re: jupiter problem
Welcome to Singastro! Nice Jupiter. Can see the 2 "eyes" clearly. May I know when and where is this photo captured? C11HD....drools.... :)
linkage2011
Re: jupiter problem
Gary wrote:Welcome to Singastro! Nice Jupiter. Can see the 2 "eyes" clearly. May I know when and where is this photo captured? C11HD....drools.... :)
some time ago
linkage2011
Re: jupiter problem
cataclysm wrote:It could be an artifact from stacking. If you are experiencing excessive movements from frame to frame, stacking registration may focused on the main globe while missed out on the outer regions. Try stacking with fewer frames and see if this will go away. :P
i use single frame could observe similar situation on the satellite of the Jupiter
att:avi to gif
sTiCkY
Re: jupiter problem
Post by sTiCkY »
it's still better than any of the jupiter pics i took on a C11 ._.
