1st attempt shooting Antares @ Bedok South Field
PETER LOO
Post by PETER LOO »
Last night the sky was partially open. 1st Attempt in shooting Antares and its nearby gas cloud, using Piggy back arrangement. Canon 500D filter Mod, ISO 1600, 1.0 to 2.5 mins, depends on when the cumulus clouds flown in, (sometime pause for 20 mins for them to pass) total exposed for about 50 mins combined, TS-65 Guide Scope, imaging lens = Canon 200mm, Combined result is very Noisy, probably need to go Malaysia for better Signal to Noise Ratio. I suppose this is a good region for intermediate level APer to practice as it consist of many objects surrounding the easily find Anteraes of Scorpio Constellation, other stars can be seen are Rho Ohiuchus, (smaller star on the left that has blue nebulosity by IC 4064; Sigma star that has red nebulosity by Sh2-9 , Globular Cluster M4, IC 4603 etc, the dark dust lane is not very clear here due to severe light pollution drowning it, again, need darker site ..
ImageAntares 25 May 2014 B by Astro shots & stuff, on Flickr
ImagePiggy Back set up by Astro shots & stuff, on Flickr
aleetk
Re: 1st attempt shooting Antares @ Bedok South Field
Post by aleetk »
Nice attempt Peter! Very nice widefield :) Hope to do some imaging with you sometime.
I've just (re) discovered that the cheap "gimme" objects are globular clusters and planetary nebulae. Just take lots and lots of short subs and you're golden. Guiding optional.
kimo
Post by kimo »
nice pics. inspiring me to get hand into cam lens Astrophotography.
PETER LOO
Post by PETER LOO »
Thanks Alex, Orly & Kimo, forgot to mention that shooting half way with F2.8, i step it up to F3.5 for remaining shots, post processing found those of F3.5 has much better (sharper) stars than F2.8. Also, Beginner, Jeremy and Lton had all recommended the use of Hutech CLS filter instead of the Astronomic CLS filter that i am using, now i found that RAWs are a bit off color balance despite using the properly pre-prepared WB shot.
Sivakis
Post by Sivakis »
PETER LOO wrote:Thanks Alex, Orly & Kimo, forgot to mention that shooting half way with F2.8, i step it up to F3.5 for remaining shots, post processing found those of F3.5 has much better (sharper) stars than F2.8. Also, Beginner, Jeremy and Lton had all recommended the use of Hutech CLS filter instead of the Astronomic CLS filter that i am using, now i found that RAWs are a bit off color balance despite using the properly pre-prepared WB shot.
Yup, if your lens is f/2.8 max aperture, it helps to lower it 1 stop for best sharpness (i.e. 50/1.8 is better 50/2.8 and X/2.8 is better X/4.0).
Thanks for sharing Peter! I would prefer to take the level down a bit but it is a good effort ! [smilie=bye2.gif]
Good stuff! Thanks for sharing. [smilie=good-job.gif]
shirox
Post by shirox »
Nice Peter!
PETER LOO
Post by PETER LOO »
Thanks guy, Lton, I was inspired by your Mersing shot in this Rho Ophiuchus region, esp the shot's
natural color with hypermoded cam .. [smilie=admire.gif] , trying to emulate but seems can never achieve it without first cooling the cam and next, going to darker site ..
