I'm looking for the Standard Meade LXD75 Half Pier.
If anyone has a one please let me know. I'll like to take a look.
Thanks,
WK
Half pier for LXD 75
Hi Wee Kong,
The drawing is attached. I have one. I do not know whether to call it Half or quarter pier.
Kochu/25-7-07
Kochu/25-7-07
- Attachments
- LXD75 Half Pier.xls
- (26 KiB) Downloaded 325 times
Re: Half pier for LXD 75
Thanks Kochu.kochu wrote:Hi Wee Kong,
Kochu/25-7-07
I got this drawing from CK Lim (he got it somewhere in the archive here)
May I know if the dimension is for the Standard LXD75 as reflected in the Meade Catalog. If yes, can I call you to check further.
Thanks,
Wee Kiong
LXD 75 Half Pier
Hi Wee Kiong,
I have not checked with the Meade drawing dimensions. The dimensions were measured by me from actual mount before giving to work shop , way back in 2004. I have been using it with out any problem. Only thing is that you have to use a longer central bolt. If you want to have a look you can drop in any evening after 9 pm .
Kochu/Mob: 9101 3971
http://www.singastro.org/viewtopic.php?t=4059
I got a 6" diameter half pier with Vixen GPD adapter made by Aftech for $225 (they can make adapters for any mounts as long as u have the drawings). You probaby just need a 4" diameter half-pier so price probably is cheaper.
"Life is not measured by the number of breaths we take, but by the moments that take our breath away"
