Selling the GSO 2" Crayford Low Profile 2 Speed Focuser For 8" and 10" Newts and Dobs, With 1.25" Adapter. In very good condition.
Price: S$180
PM me if interested.
Thanks for looking and have a nice day.
WTS: GSO 2" Crayford Low Profile 2 Speed Focuser (SOLD)
- Attachments
- Front and Back View
- GSO_LPCF_View.jpg (33.07 KiB) Viewed 1704 times
- Base plate dimensions: 3.54" x 3.54" (90mm x 90mm)
- Hole Spacing (center-to-center along telescope tube/optical axis): 70mm
- Hole Spacing (center-to-center perpendicular to telescope tube; straight line measurement): 73mm
- Hole Spacing (center-to-center perpendicular to telescope tube; measured along curve of base plate): 74mm
Below are the height:
- Minimum focuser height (with 1.25" adapter) = 62mm
- Maximum focuser height (with 1.25" adapter) = 94mm
- Minimum focuser height (without 1.25" adapter) = 52mm
- Maximum focuser height (without 1.25" adapter) = 84mm
By the way, no screws are included and the original screws for the 2" Rack and Pinion focuser is too short... at least my Celestron 8" F5 Newtonian is.
It should be able to fit on most Sky-Watcher/Orion/Celestron/GSO standard 2" Rack and Pinion focuser mounting hole. It fit my Celestron 8" Newtonian mounting hole. Below are the dimension:the mounting screw dimension between each other, hoping not to drill holes on my 10" OTA
If your default focuser is the standard 2" Rack and Pinion focuser, you'll need a extension tube to reach focus. My Celestron 8" F5 Newtonian require the extension tube to reach focus. Anyway, I got one Orion 2" extension tube and can let go at S$20 if you need it.the minimum and maximum height from base (with the 1.25 adapter in), I also worried it might not reach focus...
