Thawing my astrophotography equipment
Just took out all my hibernating astrophotography equipment (dragged them out kicking and screaming), and am surprised how much equipment I have accumulated over the years (and not used)!
Will put up an inventory soon.
Meanwhile, have done a test image of my old trusty setup using an Orion 100mm ED (remember that scope - ok, it was the 80mm version, but nonetheless - that started the low-cost APO trend) and my old-faithful ToUcam (since then I had acquired 4 more cams but none gets used as much as this one).
Hopefully, I will find enough energy to continue imaging - that is, until my MF digital back arrives this week! Heh...
Cheers!
Test image:
Re: Thawing my astrophotography equipment
Tachyon wrote:Just took out all my hibernating astrophotography equipment (dragged them out kicking and screaming), and am surprised how much equipment I have accumulated over the years (and not used)!
Cheers!
Test image:
Nice shot!! :)
And did I saw the 2 letter "MF"??? WOW!! MF leh... Not many scope can produce an image circle to cover a MF... so new scope coming??
wucheeyiun
Post by wucheeyiun »
Cheers!
Test image:
Mf = medium format or 4"x5"... good for wide field with 400mm f6.3 sekor lens or refractor with 4" focusers
cataclysm
Post by cataclysm »
[smilie=wow.gif]
Err... guys, I have only planned to use my MF for "non-astro" photography so far. I have not seen anyone mate a MF to a scope? I wonder where to get the adapters from? Furthermore, my Mamiya 645 is probably too heavy for my current set-up. Maybe we could try it with a Holga if someone finds an adapter... heh...
